B7 Headlights
Old May 26, 2006 | 12:44 AM
socaljoe's Avatar
SoCal Crew Member
Default B7 Headlights
How in hell do they come off, I don't have to take the grill and bumper off do I? I attempted to remove it today but can't seem to take the whole assembly off. I got as far as removing the air duct and the two screws holding the assembly but it won't come out. I did a search here and at audiworld before my attempt but coudn't find anything, so I thought I'd just go ahead and give it a go..but..nuttin....[:@]
Old May 26, 2006 | 12:46 AM
flyboy's Avatar
Default RE: B7 Headlights
why exactly are you trying to remove them. s for how they come off. You probably missed a bolt. thats what I do.
Old May 26, 2006 | 01:23 AM
socaljoe's Avatar
SoCal Crew Member
I wanna change the bulbs
Old May 26, 2006 | 02:52 AM
xxxdmx's Avatar
u have to remove the headlight to replace the bulb??????????
Old May 26, 2006 | 03:22 AM
socaljoe's Avatar
SoCal Crew Member
Don't the bulbs come out the back of the headlight assembly? There's no room to take the bulbs out without removing the assembly
Old May 26, 2006 | 03:25 AM
aRIf's Avatar
I dont think Audi can make such a mistake. You should not have to remove the headlight to change a bulb, I think. [&:]
I believe, Jestnomen can answer this question
Old May 26, 2006 | 04:17 AM
socaljoe's Avatar
SoCal Crew Member
I really want to change the look of my lights, I don't like the looks of the oem halogen so I got some Roadmax metal white bulbs. I've considered getting a hid kit but I don't want to have this guy's problem
Old May 26, 2006 | 04:18 AM
PandaXpress's Avatar
for the B6 u have to unbolt and move the headlight to change a bulb
Old May 26, 2006 | 05:40 PM
socaljoe's Avatar
SoCal Crew Member
The headlight was loose after I unbolted it, and it would only move about half an inch side to side. I'll give it another try this weekend
Old May 26, 2006 | 05:54 PM
cas4067's Avatar
Well you said you took out the 2 top screws. If it is the same as my 01 a4 there are a total of 3 screws. To get to the 3rd screw you need a long extension. Also the to get to the screw you have to go threw a hole in your fender. You will see it looking down from the engine bay.. Hope you understand what I mean and it works out for you..
PSULion21
Mar 18, 2012 11:28 PM
ashulga
May 7, 2010 03:40 PM
ashulga
May 7, 2010 02:56 PM
A62dot7turbo
Jun 27, 2009 10:17 AM
mschwister12
Feb 4, 2008 11:40 PM
