BACKLIGHT
Old Mar 2, 2005 | 01:30 AM
CaliA4's Avatar
Default BACKLIGHT
Hello,
On my 1996 A4 2.8Q, the oil temperature gauge and voltage gauge do not light up? Any ideas what this is caused by and how to fix it? Thanks!
Old Mar 2, 2005 | 01:31 AM
a4autocrossr's Avatar
Default RE: BACKLIGHT
fuseeeeeeeeeeeeeeeeeeeeeeee??
dash lights do blow also.......
--E
Old Mar 2, 2005 | 01:33 AM
Jestnomen's Avatar
6th Gear
small lightbulbs behind it = burnt out.
To replace:
Pull up on the black plastic piece above the steering wheel. Underneath there are two philips screws. Remove them and the cluster will slide out.
Stick your hand behind the cluster and remove the 3 plugs, and CEL wire. The light bulbs can be changed from the back of the cluster. NO you can can't buy the bulbs at autozone. Yes you can buy them at the dealer for a few bucks.
Old Mar 2, 2005 | 01:36 AM
mahh bad Jest
--E
neur0tic
Dec 8, 2024 12:53 PM
foss99
Aug 9, 2009 10:44 AM
foss99
Jul 19, 2009 06:05 PM
Dallas09
Feb 14, 2008 06:37 PM
Diavan
Dec 29, 2005 07:02 PM
