is it bad that I turned the cam gear the wrong way
Old Aug 3, 2005 | 02:26 AM
Yuikio's Avatar
Default RE: is it bad that I turned the cam gear the wrong way
There's no way you need to rebuild your engine after this. Maybe you have bent a valve or two or more, but you haven't been whaling on the car, just trying to get it to turn over, right? I don't know exactly where the timing should be set. I'm sure you can find it. Did you not mark on the belt where it was when you took it off?
Old Aug 3, 2005 | 02:49 AM
turbo's Avatar
Yah I was only trying to start the car, after changeing the belt.
I did mark it but when I put it back together it would only turn over, not starting.
Then I started to F with it and now it sounds like it is not making eney compression.
How much are valves? should I upgrade if I do need to change them? if so what ones should I get?
I have an 02 A4 tip with Revo K-04.
Old Aug 3, 2005 | 03:58 AM
lidonnit's Avatar
Well maybe i'm just talking about mechanics in Australia, but the cost of changing vavles and repairing any damages is more expensive than rebuilding the top end (new head)
Old Aug 3, 2005 | 09:34 AM
david9999's Avatar
I would suggest not doing anything further with the engine and take it to a mechanic before you do any more damage.
Old Aug 4, 2005 | 04:22 AM
lidonnit's Avatar
ORIGINAL: david9999
In your case I think this may be the best option. Not having a crack, just think without seeing or hearing, we are all given advice blind & deaf.
TheDane
Mar 16, 2010 05:00 PM
