Bad Turbo Or What?
Old Oct 22, 2006 | 11:39 PM
AudiTurbo's Avatar
Default Bad Turbo Or What?
I have a 98 b5 a4 1.8tqm and i am really having a lot of trouble. The car has 95 k on it and was well took care of but i think that my turbo is out or something...It didnt feel like it was boosting when i bought it, so I bought a new diverter valve for it and nothing. Then i just thought it was under powered, so i bought the giac 1bar ecu, and a boost gauge, and it is still running like 2psi....i dont know what to do now..i even changed the n75 valve and nothing changed. I also took the boot off of the turbo to see for shaft play and there is none, so i really dont know what to do now...i am going to buy a new turbo, but wanted to know what you all thought was the problem? Im running only 2psi, instead of about 14.7, so please some one tell me what might this be. thanks
Old Oct 22, 2006 | 11:43 PM
kraylon's Avatar
Default RE: Bad Turbo Or What?
it may be a good sized vacum leak check that out i had the hose on the "pancake valve" rip on me once it ripped on the bottom so it was hard to see and it made my car boost at like 5psi changed that hose and back up to 18psi we went
Old Oct 22, 2006 | 11:48 PM
AudiTurbo's Avatar
WHere is the panckae valve? and why wouldnt i be running any boost at all?
Old Oct 22, 2006 | 11:52 PM
acetrebo's Avatar
usually when the turbo goes, there is a lot of noise, and also shaft play that you already checked for.
Are you getting any codes?
definitely get the codes read, and look for leaks. Bad hoses are common sources of problems on these.
Old Oct 22, 2006 | 11:55 PM
AudiTurbo's Avatar
there is no shaft play, and there is no codes being thrown.....maybe the exhaust side bad, or the wastegate?
Old Oct 23, 2006 | 12:00 AM
kraylon's Avatar
the pancake valve is in the turbo inlet hose on the right pretty much in plan veiw
acetrebo's Avatar
Sounds like a bad DV, or a hose falling apart somewhere.
Check the hose that goes from the front of the intake down to the turbo. Its hard to get to, but its a common point of failure.
Old Oct 23, 2006 | 12:05 AM
AudiTurbo's Avatar
I just put a new dv valve on it.......maybe i could get a new pancake valve, but when i pulled off the intake tube to the turbo there was no shaft play. i dont really know what else to look at now.....
Old Oct 23, 2006 | 12:09 AM
kraylon's Avatar
i wouldn't just go out and get a new pancake valve check the hose also check you turbo inlet hose i wish i had a picture of where the pancake valve is im not sure what the valve is really called.
Old Oct 23, 2006 | 12:11 AM
AudiTurbo's Avatar
round flat valve just off of the turbo inlet? does that have a diafram?
