Bank 1 lean HELP!
Old Jul 13, 2007 | 04:40 PM
vassar007's Avatar
Default Bank 1 lean HELP!
So the car throws a bank 1 lean check engine light every fifty or so miles. When I scan it with OBDII and clear the fault code, the car runs perfect in stock chip setting. BUT if I turn on the APR stage 1 software, the car gets angry. At 80 mph plus in fifth on the highway under hard acceleration, it flashes the check engine light. Obviously, I don't run the car in chipped mode becaues the flashing check engine is really bad news. Any ideas on what this might be? I fixed a vacuum line leak off the fuel pressure regulator and changed the fuel filter.
Thanks,
JPF
Old Jul 13, 2007 | 06:13 PM
CRAZYHAWK's Avatar
Default RE: Bank 1 lean HELP!
Check all the vacuum lines. Look at the "L" shaped formed
hose, between the intake manifold and the G-12 reservoir.
Old Jul 14, 2007 | 06:52 AM
david9999's Avatar
Please post the actual numeric code.
Old Jul 14, 2007 | 01:45 PM
CRAZYHAWK's Avatar
Origonal Part 058 133 783L
Replaced with 06B 133 783 BC
The Audi Parts Dept. keeps these by the sales
window, as they tear frequently.
Tadyswoows
Jan 2, 2010 07:07 PM
Sp33d07
Aug 14, 2008 01:27 AM
seana4
Oct 31, 2007 06:23 PM
turbo kraut
Nov 13, 2006 09:51 PM
gcain99
Aug 12, 2005 12:40 AM
