Battery question
Old Dec 10, 2007 | 10:15 PM
ek4__'s Avatar
Default Battery question
I have a 2000 Audi A4 for some reason the battery keeps getting drained over night. its been doing this for the last few days and im tired of wakeing up every morning to charge it. what could be causing this?
Old Dec 10, 2007 | 10:17 PM
Bogie's Avatar
Default RE: Battery question
electrical short (drain), bad battery, bad starter solenoid....
Old Dec 10, 2007 | 10:27 PM
ek4__'s Avatar
well what ive been doing everynight is unhooking the battery and if i do this the battery is fine to start the next morning. but if i leave it hooked up the just gets drained. How do i check for a bad starter solenoid? imma go get the battery test on Wedesday too.
Old Dec 10, 2007 | 10:31 PM
hiwords's Avatar
most likely probably a short. vag com can pick it up i think. otherwise, you can have fun checking every wire behind the dash and the engine bay lol
Old Dec 10, 2007 | 10:34 PM
Bogie's Avatar
If it's fine when you disconnect the battery overnight, then it's probably not the battery. bring the starter in somewhere where they can bench test it, like AutoZone. That's how I found out my starter solenoid in the VW went bad. I replaced the starter and had no trouble with it to the day I sold that car.
Old Dec 10, 2007 | 10:39 PM
ek4__'s Avatar
im new to these audi cars. im use to fixing honda only. well i forgot to add that there use to be a amp and sub hooked up but it got taken out so im guessing this could be causing the problem too. thanks for the help too.
Old Dec 10, 2007 | 10:45 PM
Bogie's Avatar
Get Learning. The Audi A4 Search will pull up more info that you are looking for that you can read in one night. Get Doing.
dtkelley2005
Feb 12, 2010 12:39 PM
hannesr
Feb 22, 2007 01:23 AM
hannesr
Feb 21, 2007 03:29 PM
pharaoh
Oct 9, 2006 09:05 PM
