Beefier transmission/clutch?
Old Aug 4, 2004 | 07:21 PM
norcaltrojan's Avatar
Default Beefier transmission/clutch?
This is still a ways off, but I'm curious about what you guys would recommend as a good transmission/clutch combo upgrade to go along with a K04 turbo upgrade?
Old Aug 4, 2004 | 09:25 PM
Doose's Avatar
Default RE: Beefier transmission/clutch?
When I upgraded to the K04 I also put in a South Bend / Unorthodox Racing clutch and flywheel. Here is the link.
South Bend Clutch
It cost me about $1000.00 shipped. Great clutch IMO. Drives a bit different, grabs a lot more in first and second. Takes a bit more gas to get off the line. Third is still long and strong. I still have the stock tranny, it's been fine with my other upgrades. Hope this helps, let me know what oyu think about the South Bend / Unorthodox site and products.
"costed me"? what was that?
Old Aug 4, 2004 | 10:05 PM
So you don't have to upgrade the trans at all? Just the clutch? Mind you, this will go on an S4 with K04 turbos.
Looked around the site a little bit. It could use some work. It seems a little difficult to navigate.
Old Aug 7, 2004 | 06:05 PM
Doose's Avatar
Yeah, I agree on the site needing a bit of work. Your tranny should be fine with your stock tranny and K04's. Actually I didn't realize you were talking S4. Just to be sure, I'd call them and verify that. I got the clutch good for 240 ft./lbs. of torque, you'll probably want to look into the DXD series, stage II or III. I've been more than happy with mine, although there is definitely a break in period. Mine was about 600 miles or so. Keep me posted on what you end up doing, I'm interested to hear what you decide.
Old Aug 7, 2004 | 06:44 PM
I definitely will. The turbo upgrade I'm speaking of in particular is the APR K04. At this point I know for sure I will have to get a stronger clutch to handle the 400 hp, but I don't wanna get all that stuff installed only to find out the transmission will drop out under the added stress. So I guess I'm not really asking about the clutch, but moreso if it'll be safe to run the stock transmission.
Old Aug 8, 2004 | 10:06 AM
1.8t20v's Avatar
APR has K04 now????? Or are you talkin about the stage III? Does that use K04? I was going to go with GIAC chip for future K04 but prefer APR since there is a dealer near by. More info????
Old Aug 10, 2004 | 02:33 AM
Yeah they do. Keep in mind I'm talkin about an S4 here so it's a little different. Check it out, I can't wait til I have enough money to throw this sucker under the hood!!
They have kits for the 1.8 but they aren't K04s . You should still check it out though, their other kits are still pretty sweet.
Yeah, I'd like to keep it in the APR family as well if I can.
heathcliff2807
Sep 21, 2009 02:55 AM
sjl4141
Dec 3, 2008 12:03 PM
mdudu
Sep 15, 2008 06:07 PM
norcaltrojan
Aug 9, 2004 10:03 PM
