Best option for fixing P1545 problem
Old Mar 26, 2012 | 02:16 AM
Soulraver's Avatar
Default Best option for fixing P1545 problem
I got an '99 A4 V6 last week and it has no power, shows check engine with p1545. I researched a lot into this and it seems the best way to fix it is take it to a dealer or get Vag-com. I don't mess with my car much is it better to get the cable and software? Also i noticed some vag-com cables on ebay, but it states they only work on certain bussystems, not on VPW, PWM or CAN-bus is that what my car has or do those cables work as well? Thank you for any replies, trying to get my car back on the road as cheap as possible.
Old Mar 26, 2012 | 06:42 AM
bradtyler02's Avatar
Amazon.com: OBD2 OBD II Diagnostic USB Cable For KKL409.1 VAG-COM 409: Camera & Photo
I just ordered this one and it worked great after I was able to download the right drivers. Then got to Ross-Tech: Home and download the free VCDS Lite program. You can do quite a bit with it. You will have to pay 100 bucks to activate it fully, which you will need to do to do a TBA (throttle body adaption/ alignment). A quick fix that may work and is worth a shot is to simply disconnect your battery for about 15 minutes, then reconnect and put the key in the on position for a few minutes. the TB may realign itself. But, make sure you have your radio code, or you will be without tunes until you get it.
Post your questions in the B5 specific sub forum for more timely and accurate help. Welcome to the forums.
Old Mar 27, 2012 | 08:41 PM
Soulraver's Avatar
Thank you for the quick reply, I will end up buying the cable. One quesiton though, i tried the battery disconnecting like you stated, but after leaving both the neg and pos battery cables off and away from the battery, i came back 2 hours later, plugged it in and it was like the battery was never disconnected. The radio still works and is on the same station i left it on, the chk engine light is on... is there some kind of back up on these cars?
Old Mar 28, 2012 | 06:43 AM
That's interesting... I've never heard of that happening before. No matter what, if I disconnect my battery, the radio goes into safe mode...
One thing you might try is disconnecting both cables, then touching them together. This would allow any trapped power to dissipate.
Old Mar 29, 2012 | 01:51 PM
Soulraver's Avatar
So i went back and unplugged the battery, touched the two cables, no sparks, inside no power in the car at all, left both cables unhooked for 80 min, hooked them back up and same thing, radio still on same station no security code, check engine on etc. This is the strangest thing. Anyone have any input as to why its happening ?
Old Mar 29, 2012 | 09:13 PM
very weird...
maybe try disconnecting just the negative?
Old Mar 29, 2012 | 09:14 PM
aaroncar's Avatar
Hi Super VAG K+CAN for Audi maybe can meet your demand.It can CAN security access code reading,Engine security code and kilometers reading and can do key programmer.Maybe you can have a look.
Old Mar 30, 2012 | 12:12 AM
budhani786's Avatar
Ive left the battery disconnected overnight plenty of times before. Never once needed a radio code. same with my buddy in his a4. ive done both negative only and both cables. the radio still works. I think its just normal.
Stephenwhite990
Jul 3, 2013 02:25 PM
Pissed of Audi Customer
Jul 19, 2011 02:52 AM
elye1231
Jul 6, 2011 10:58 AM
jonzo
May 18, 2011 01:15 PM
mr.cAp
Sep 14, 2008 09:01 PM
