Best place to get a GIAC flash
Old May 19, 2006 | 12:59 AM
  #21
miked's Avatar
Default RE: Best place to get a GIAC flash
Yes you should replace it. You can pick up a 710N from your stealership for like $35. What does your turbo sound like? If it sounds like a siren or a whine...your turbo is goin. Where do you feel the surge?
Old May 19, 2006 | 01:03 AM
  #22
blkapra4's Avatar
i will punch the gas and it will buck slightly than not really accelerate hard. (accelerates a lot better at partial throttle) Honestly the turbo just sounds like its blowing air straight into the atmosphere. not really a whinning but it sounds like i just put the ac on in the car full blast
Old May 19, 2006 | 01:07 AM
  #23
miked's Avatar
Sounds like a boost leak or a shot DV. Noises are hard to diagnose so I cant help with the turbo but I'm sure that if you find a leak (boost/vacuum) anywhere it could fix it.
Old May 19, 2006 | 01:12 AM
  #24
blkapra4's Avatar
thanks for the advice.. i know some noob's description of a noise isn't easy to diagnose a problem. but i am thinking its the dv especially because it pulls fine at partial throttle and fyi k03s is 214chp. Do you have a recomendation for a particle type of dv seeing as you have an 01 too?
Old May 19, 2006 | 01:16 AM
  #25
miked's Avatar
ORIGINAL: blkapra4
Where the hell did you hear that a ko3s is 214chp?? Its 170 dawg. 20+ from the reg. 150 in 96-00.
Mr. Phil
Jun 2, 2011 08:12 AM
pjunk1
Aug 25, 2010 05:48 PM
BenDiesel
Apr 10, 2007 01:00 AM
timbo108
Mar 22, 2007 07:43 PM
scarzie
Jan 18, 2006 05:59 PM
