Big Brakes
Old Oct 7, 2007 | 09:11 PM
khj677turbo's Avatar
Default Big Brakes
Tried researching some ideas about brakes. Lots of people go for porsche brakes, are there certain models that most people get? 996, cayenne?
I presume that its more cost effective, but can someone explain some applications. Im not too educated on brakes.
Old Oct 7, 2007 | 09:17 PM
qUaTtRoA4's Avatar
Default RE: Big Brakes
I have heard that many people on here are going w the A8 rotors and TT carriers...
though it sounds like you are talking about going w a bigger calipper as well....if so, search around some of our sponsors sites...
I have only seen maybe 4 sets of big brake kits on here...but I am sure some1 will be able to point you in the right direction....
gl!
Old Oct 7, 2007 | 09:30 PM
well im sure the a8 would be fine. just wondering what the limits are, if i picked up some porsche brakes how hard would it be to put on the a4 that sort of thing.
Old Oct 7, 2007 | 09:36 PM
qUaTtRoA4's Avatar
^it would be a huge pita to make a set of mounting brackets for another set of calippers and a BBK for your car just for the front would be about 2500$ cheapest....I would go w the A8 rotors and TT carriers, there's a kit for like 300-350$, you could do a quick search and find it pretty easily...
just do a quick search, unless you are tracking your car or have a BT you don't need bigger calippers (and they aren't worth it if you are going for looks)
I have heard of people using boxster calippers, this may be pretty inexpensive (if you can find a set at a junkyard)...
If you have a friend who is a fabricator, or you are a pretty good welder, you may want to look into some hybrid calippers...
well, hopefully something up there will be helpful
Old Oct 7, 2007 | 09:41 PM
cincyTT's Avatar
I'm make believe
porsche brakes take special carriers that you can only get from ecstuning. You will also need 17" wheels are larger to run them.
Old Oct 7, 2007 | 09:52 PM
Jeff's Avatar
Zombie Defense Force
get some alcon or stop tech and you set
Old Oct 7, 2007 | 10:02 PM
cincyTT's Avatar
I'm make believe
arent both of those $2k kits? You should be able to get some large rotors and a 4 piston for under $1500
Old Oct 7, 2007 | 10:41 PM
SAudi's Avatar
ive heard of people putting on S4 calipers, apparently there the same size only instead of a single piston its 2 so more power to stop.
Old Oct 7, 2007 | 11:02 PM
kolan67's Avatar
ORIGINAL: cincyTT
i can run the ecs porsche brakes on my 17' rims stock?
Old Oct 7, 2007 | 11:14 PM
cincyTT's Avatar
I'm make believe
the boxster kit will fit 17's and the cayman and larger kits need 18's
