Big Brakes
Tried researching some ideas about brakes. Lots of people go for porsche brakes, are there certain models that most people get? 996, cayenne?
I presume that its more cost effective, but can someone explain some applications. Im not too educated on brakes.
I have heard that many people on here are going w the A8 rotors and TT carriers...
though it sounds like you are talking about going w a bigger calipper as well....if so, search around some of our sponsors sites...
I have only seen maybe 4 sets of big brake kits on here...but I am sure some1 will be able to point you in the right direction....
gl!
gl!
^it would be a huge pita to make a set of mounting brackets for another set of calippers and a BBK for your car just for the front would be about 2500$ cheapest....I would go w the A8 rotors and TT carriers, there's a kit for like 300-350$, you could do a quick search and find it pretty easily...
just do a quick search, unless you are tracking your car or have a BT you don't need bigger calippers (and they aren't worth it if you are going for looks)
I have heard of people using boxster calippers, this may be pretty inexpensive (if you can find a set at a junkyard)...
If you have a friend who is a fabricator, or you are a pretty good welder, you may want to look into some hybrid calippers...
well, hopefully something up there will be helpful
