Big Injector Question
Can the big injector file be used in conjunction with the ko4 file. I was told by an audi performance specialist that the BI file was a good alternative to the k04 but would not be used with it but I hear of people all the time with bigger injectors. What is the deal with the big injectors. I know why you do it, the questions I have is when do you use them, how much of a difference do they make, are the tt 225 injectors good enough and what if I have a k04? This was never properly explained to me by the speacialist.
If you are asking if you can use two ecu flash's at the same time, no. Most people arent even going to understand what you are talking about anyway.... Big injector files are only for the B6 as far as I/ 99% of the members know. I know you were told a while back by someone that there is a big injector file for your car (B5), but no one except for you has ever mentioned it. The only thing i know about related is to get a k04, the aggressive k04 file and supporting mods including bigger injectors... Other than that, i dont know of any way to properly use big injectors on a B5 unless you have a BT setup.
it all depends on what file you go with, some Ko4 files require bigger injectors 310cc injectors that the pc-16 and i think the hammer file.. the less agressive ko4 file runs an AFPR set to 5 bars... but i ran 310cc injectors with my ko4 file and just messed with the fuel presure till it ran right..
Yeah you guys were tellin me its not for my car but the audi performance specialist at Evolution Motorsports said I can. I don't know I 'll ask him again and see if this guy knows what the heck he is talking about.
ORIGINAL: NuYorka103185
I would think tt225 injectors would be too big for a KO4. At least for "proper" tuning. They run at 383cc's as far as I know. If 310cc's are good enough for the pc-16 file you aren't going to need much more fuel flow than that.
Rough stuff
