Big Malfunctions to my A4
Old Nov 14, 2004 | 01:57 PM
TetrickA4's Avatar
Default Big Malfunctions to my A4
Hey Guys,
I need help with a malfuntion I had last night. I drove me and my girlfriend to see a movie last night and after the movie we went to her house.(CAR WAS FINE). But when I left her house, I tried and turned on my head lights and only the parking lights and tail lights came on. I started to freak out, I checked the bulbs and they were fine. But my high beams worked fine if i pulled the arm to me. So I decided to jump back in my car. And drove back with my high beams. Well, my heat kept fluctuating from on to off when I was driving home. I turned it to manuel and it kept doing it also.... I dont know what is wrong with the A4. I am taking it a guy tonight so he can work on my car on Monday but I dont know if is something i could fix. Thanks
Matt
Old Nov 14, 2004 | 02:54 PM
david9999's Avatar
Default RE: Big Malfunctions to my A4
Check fuses, check relay, check for codes.
Old Nov 14, 2004 | 02:59 PM
TetrickA4's Avatar
That would be a lot of fuses that went out in a 2 hour period. I mean also my horn didnt work at all and neither did the outside temp. indicator.
Old Nov 14, 2004 | 11:08 PM
A4Aram's Avatar
same thing happened to me but it was with my turn signals everything was fiune even the bulbs but they didnt work when i tried to use them. I found out it was my relay and i had to get that fixed.
Old Nov 15, 2004 | 01:14 AM
TetrickA4's Avatar
yeah well im think cuz most of that is on the steering colum, it might just be the connection...not sure, i have my car at the shop right now so he should have it fix by tomorrow.. Fuses werent it cuz I replaced ALL off them (that cost a lot of money for nothing) but thanks guys
Old Nov 15, 2004 | 02:00 AM
sfordeso's Avatar
Now you got a whole stash of fuses for when they go in the future
Old Nov 15, 2004 | 03:39 PM
99a4audi's Avatar
u might have blown a fuse
Old Nov 15, 2004 | 04:01 PM
Jestnomen's Avatar
6th Gear
ORIGINAL: 99a4audi
he already said he changed all the fuses.
Old Nov 16, 2004 | 02:06 AM
AMeicher's Avatar
Sounds like an ECM problem, get it scanned, even if it doesnt happen anymore, because if you let it go, it'll burn you later.
Old Nov 16, 2004 | 10:54 PM
1.8t20v's Avatar
I had the same problem with my headlights a while ago, it was the light switch itself that went bad. It was the second time it was replaced. Not sure about the heat though.
rhubbard
Jan 5, 2013 06:54 PM
johnblaze
Jan 15, 2007 01:12 AM
johnblaze
