Blinker wont stay on
Old May 19, 2007 | 06:54 PM
jwag1999's Avatar
Default Blinker wont stay on
So I got a 2000 A4 1.8t auto. The blinker right and left will work one or two times then stops working. It is tickin me off. I checked the fuse its ok, the hazards work just fine. I replaced the entire blinker switch, andits still not working!?! What can I try? What can I do? I dont what to go and get robbed by the dealer. Thanks for your help.
Old May 19, 2007 | 06:58 PM
akoby9's Avatar
Default RE: Blinker wont stay on
you need to replace your turn signal relay... or is that what you meant by the blinker switch?
I had this same thing happen to me... I'm pretty sure your relazy is shot
akoby9's Avatar
Old May 19, 2007 | 07:21 PM
Jeff's Avatar
Zombie Defense Force
i think your blinker fluid is low
Old May 19, 2007 | 08:28 PM
01A4T's Avatar
ORIGINAL: Jeff
Lol, i think everyone checks the "blinker fluid" first and foremost
but yeah, it is probably the hazard relay/ turn tignal relay (same thing)even if your hazards work, and your signals are working poorlyor not at all. itslike a 40-50 dollar part at the dealer, and you can replace it in about 5 minutes.
Old May 20, 2007 | 07:11 PM
jwag1999's Avatar
Thanks Jeff she was a bit low on the fluid butI filled 'er up......yeah anyway Thanks for the tip about the relay I just assumed that if the hazards worked the blinker would as well. So I'll try the relay and get back to ya'll
Old May 21, 2007 | 02:34 PM
Audi A Fizzle's Avatar
Same thing happened to me, its the relay switch for sure, and in my 98 the actuall flasher button IS the relay switch
Old May 21, 2007 | 05:55 PM
jwag1999's Avatar
So $40 bucks to the dealer and 10 min of my time and she is good to go!! Thanks so much for your help, akoby9 thanks for the link to the tutorial on how to replace the relay. Very Easy Fix!!
adamlouks
Jan 19, 2012 08:46 PM
viperpit07
Jul 25, 2011 01:43 PM
Jeff
Jun 29, 2009 10:50 PM
chris18t99
Dec 29, 2008 05:13 PM
chris18t99
Dec 27, 2008 09:28 PM
