96 a4 2.8 wont stay running
Old Mar 16, 2011 | 04:05 PM
adamlouks's Avatar
Default 96 a4 2.8 wont stay running
have a 96 a4 2.8 non quattro. had trouble starting and changed temp sensor now starts without a problem. now it won't stay running unless I give it gas. won't idle and it sounds like a diesel does anyone have any ideas I could try?
Old Mar 16, 2011 | 10:07 PM
adamlouks's Avatar
Anyone??
Old Mar 16, 2011 | 10:42 PM
erasmmuss's Avatar
Trottle position sensor or knock sensor u should vag scan your car and see whats up
Old Mar 17, 2011 | 07:54 AM
adamlouks's Avatar
I have vag-com but my laptop isn't working worth a crap. Is knock sensor same as cam sensor? Thanks for reply
Old Mar 17, 2011 | 07:57 AM
adamlouks's Avatar
Also sometimes it will drive fine if I give it gas and other times I can hold it to the floor and barely move then it will take off after about 10 seconds holding it to floor.
Old Jan 19, 2012 | 05:15 PM
dbcooper024's Avatar
Default do u have a vag com
i have a laptop if u have a vag com maybe we can help each other out????
Old Jan 19, 2012 | 08:46 PM
ImTheDevil's Avatar
Those are two different sensors. Limp the car to autozone and have it scanned for codes. That's always the first step. Do a search for "throttle alignment" and you'll find a way to more or less align the throttle position sensor to smooth out the drivability.
rmr1499
Nov 4, 2017 12:27 AM
viperpit07
Jul 25, 2011 01:43 PM
DEADROCK
Jun 27, 2010 01:42 PM
rummy
Nov 1, 2009 09:58 PM
Cloud2Ground
May 9, 2007 02:55 AM
