Boost guage reading question?
Old Apr 25, 2005 | 11:23 PM
hypnotiks's Avatar
Default Boost guage reading question?
i installed a Auto meter boost gauge.......Homestly i dont know if the reading is bad or not.... when i turn on my car it reads -15 to -10, once i start driving it goes up to boost +10 to +15.......once i take off my foot of the gas it drops to -20....... i am trying to see if i have a leak somewhere in my vacum lines.
Old Apr 26, 2005 | 05:54 AM
Transverse's Avatar
Default RE: Boost guage reading question?
Are you chipped?
Mine only gets to about +5psi but I have old hoses so I'm pretty sure I'm leakin somewhere. You're supposed to push about 8psi and 20 vac. is good (stock).
-T
Old Apr 26, 2005 | 06:18 AM
brrman's Avatar
-15 to -20 In HG is normal for idle. When driving you will still be in HG if you are off the gas... You only hit positive numbers when boost outweighs vacuum. So -20 is GOOD when at idle. It means you have no leaks under vacuum.
If you are stock you should only see a positive of 6-9psi. 12-18 if you are chipped...
Old Apr 26, 2005 | 07:47 AM
2kaudi's Avatar
What he said
Old Apr 27, 2005 | 03:22 AM
hypnotiks's Avatar
thanks guys....
i have a MTM chip.... so i guess am doing good... i am doing about 15 t0 19 psi
what mod comes next?
Old Apr 27, 2005 | 03:24 AM
Jeff's Avatar
Zombie Defense Force
a new DV if you havent up graded that. ehaust, intake and a larger turbo
Old Apr 27, 2005 | 03:31 AM
hypnotiks's Avatar
I already change it with a 710n but i want to get the forge DV.....i should get an exaust soon.....
Old Apr 27, 2005 | 03:33 AM
Jeff's Avatar
ya i would get exhaust. if you want to you could remove your cat. i have herd you loose a bit of low end power but you gain high end power. it is illegal tho
iamderrik
Jun 11, 2010 09:44 PM
ltsheets
May 4, 2008 12:47 PM
outinfront
Dec 9, 2007 01:25 AM
keko2004
Aug 16, 2006 02:56 AM
a4bsix
Jul 6, 2006 04:28 PM
