boost spikes
Old Jul 16, 2005 | 06:23 AM
Jeff's Avatar
Zombie Defense Force
Default boost spikes
my car is tuned to run at 10psi, however yesterday while driving i would spike at 15psi then drop back down to 10psi. today i would hit 20psi and stay there all the way to red line. i got a ton more power out of it but i did nothing to make the boost level go up. i have herd of boost creeping but not 10psi worth of it. what could be going wrong or is this safe to let occure
Old Jul 16, 2005 | 02:54 PM
GTMA4's Avatar
Default RE: boost spikes
are you running a dv or bov? What year, make?
Old Jul 16, 2005 | 03:36 PM
EvilA4's Avatar
It sounds like your running APR's chip so you should be spiking at 20psi... thats pretty normal.
Old Jul 16, 2005 | 04:04 PM
Peteman187's Avatar
He's running special software on a T3/T4. He said he boosts at 10, you should not be spiking quite that high. My chip is 14 and SOMETIMES ill spike 18 tops.
Old Jul 16, 2005 | 04:15 PM
Jeff's Avatar
ya i have a manual boost controller and it is set at 10psi. i have a 2001 a4 1.8t. and i have a dv. but what would cause it to jump up to 20psi with out doing anything. im afraid to drive it cus it might go to 25psi. if this happens i think ill run hella lean cus its not tuned for that and possible blow my engine
Old Jul 16, 2005 | 04:48 PM
TomRitt's Avatar
I had this same problem. I have a shitty ball spring mbc and the ball got stuck, causeing the same problem, check it
Old Jul 16, 2005 | 04:50 PM
black b5's Avatar
sounds like the MBC spring could be getting weak
Old Jul 16, 2005 | 04:51 PM
black b5's Avatar
ORIGINAL: TomRitt
tom is quick
Jeff's Avatar
ya ill go and check that out cus that would explain y it was increasing as teh night when on i just dont wanna blow my engine
BoostLover97
Feb 23, 2014 09:33 PM
b5audi1.8t
Feb 26, 2009 01:38 PM
typhoonfd
Jan 3, 2008 01:40 PM
JohnnyBravoA4
Jun 22, 2006 03:54 PM
PaulA4
Dec 13, 2004 08:29 PM
