Brake Job.... Help!!!
Old Jan 20, 2008 | 03:22 PM
  #21
crosswire's Avatar
Default RE: Brake Job.... Help!!!
I apologize, this is my first time working on my car, and I can do the work, but I have a hard time remembering what everything is called
Old Jan 28, 2008 | 12:24 AM
  #22
crosswire's Avatar
Ugh, well I got the front and rear rotors and pads replaced. Now I have a couple of different problems. First ever since I replaced the front set of pads and rotors my abs/brake sensor has been going off whenever I drive the car for awhile. I thought I had fixed it by cleaning the front sensors off, but it just came back on my way to work today. I'm going to get the car to autozone to have codes run on this on wednesday. Second, I've been noticing a bit of vibration on the front end when I'm going down the road like a rubbing/grinding noise. I've also recently get a slight squeak whenever I turn the steering wheel to the right. I also pushed down on the front passenger side of the car and it squeaks when i push down on it. Please give advice!
Mike
Old Jan 28, 2008 | 12:33 AM
  #23
manufan's Avatar
How did you end up getting the stripped bolt out?
Old Jan 28, 2008 | 12:42 AM
  #24
crosswire's Avatar
I had to grind it off. Unfortunately, I got a bit of the arm that It went into so I had to use a lock washer to give it a nice tight fit.
Old Jan 28, 2008 | 08:32 AM
  #25
crosswire's Avatar
bump
abc27
Aug 25, 2013 04:19 PM
NorthernComfort
Sep 19, 2007 07:54 AM
