Brake light warning.. but it works!?
Old Sep 28, 2007 | 04:52 PM
HeIsAudiHere's Avatar
Default Brake light warning.. but it works!?
Brake light message keeps coming up on my dash. I went to change the bulb... they are okay. I then had a friend confirm that all the brake lights work when I hit the brakes with lights on and off! Anyone have this problem? What should I do?
Old Sep 28, 2007 | 05:24 PM
Default RE: Brake light warning.. but it works!?
Forgot to tell. 2004 A4
Old Sep 28, 2007 | 05:34 PM
18tq_redflag's Avatar
Running low on brake pads? Sensors in the front..
Old Sep 28, 2007 | 05:37 PM
I checked it out. There is a symbol for break pad wear. This message literally reads "Brake Light".
Old Sep 28, 2007 | 06:09 PM
cincyTT's Avatar
I'm make believe
The brake light will flash and beep if the brake fluid is low, but i would still check the fluid anyways
Old Sep 28, 2007 | 08:22 PM
qUaTtRoA4's Avatar
sounds like a bad sensor...your under warranty aren't you?
take it in!
gl!
zzr
Nov 9, 2009 05:55 AM
rodick
Sep 8, 2008 05:48 PM
LampyB
Apr 11, 2007 01:24 AM
tp
Aug 18, 2004 11:37 PM
