brake lights
Old Apr 8, 2006 | 07:50 PM
coheed's Avatar
Default brake lights
For some reason my anti-lock brake light is on and my emergency brake light is flashing, and I can't figure it out. My brakes squeek a little, but doesn't seem like it's the prob. what do you guys think?
Old Apr 9, 2006 | 11:33 AM
dankhound's Avatar
Default RE: brake lights
Checkk your brake fluid level. If that is ok you probably have a failing abs control module.
Old Apr 9, 2006 | 06:02 PM
blever's Avatar
It could be a problem with one of the wheel sensors. I had one go bad on mine & had the lights on just like yours.
Old Apr 9, 2006 | 07:52 PM
coheed's Avatar
how much does a new brake senour cost/
Old Apr 9, 2006 | 07:56 PM
techbod's Avatar
a lot, I recon your due for rear break pads "hand break/emergency break"
Old Apr 10, 2006 | 12:57 AM
blever's Avatar
First you need to find out what exactly is wrong. A sensor is going to be more than $150 from a dealer. I damaged one when I was replacing the cv boots. Somehow I managed to catch the sensor when I was reinstalling the axle. You may have to take it to a dealer to have them scan it it for codes. I used a wiring diagram & an ohm meter to check each sensor. I checked them at the connector to the abs module.
astaples81
Apr 26, 2015 05:03 PM
Tourbo24
Jan 2, 2012 10:31 PM
pezster
Oct 30, 2008 11:37 PM
m5systems
Dec 19, 2006 06:30 AM
cbing28
Mar 19, 2006 01:33 PM
