Brake lines
Old Oct 17, 2006 | 12:05 AM
ADubyaD's Avatar
SoCal Crew Member
Default Brake lines
Do you guys know how much of a pain in the *** it is to change the brake lines? i wanna do stainless steel... it wasnt that bad when me and my bro did our camaro, but that's big and simple
Old Oct 17, 2006 | 12:14 AM
Trey25's Avatar
Default RE: Brake lines
Its actually pretty easy, just remember the copper fittings are very brittle and warp easily, if that happens you wont get your wrench to fit to remove the line. So if they're really tight use some WD40 or liquidwrench.
Old Oct 19, 2006 | 03:05 AM
Mike@PureMS's Avatar
Pick up an 11mm FLARE NUT WRENCH.
They bite on more than just 2 sides of the nut and provide a more secure grip on those soft brass fittings.
Spray the fittings down with penetrating oil like PB Plaster, Kroil, or Liquid Wrench (WD-40 isn't a penetrating oil).
It'll help loosen up those fittings for you.
Boober
Nov 21, 2010 10:53 PM
Splbasshead
Aug 26, 2010 02:01 PM
NeXeA500
Mar 21, 2009 12:15 PM
Murderface
Jul 30, 2008 10:24 PM
oczalevsevy
Mar 20, 2008 07:29 AM
