Brake Pulse
Old Apr 28, 2005 | 12:56 AM
jsatterf's Avatar
Default RE: Brake Pulse
Bentframe, one for each wheel correct?
Old Apr 28, 2005 | 01:08 AM
BFlan2001's Avatar
correct...but most likely it's just one, they won't go out at the same time...
Old Apr 28, 2005 | 01:09 AM
jsatterf's Avatar
Anyway to know which ABS sensor?
Old Apr 28, 2005 | 01:14 AM
BFlan2001's Avatar
have a friend drive your car and listen from outside.....just have him stop right next to you, and do it on both sides, that will give you a better idea than just doing it from one side...
Old Apr 28, 2005 | 01:48 PM
Shaunp05's Avatar
if you suspect the Abs sensor, have a look at all of them
try pick up any dirt around the sensor or a bad wire, and check the condition
of the Tone Ring on the shaft, to see if there is any broken or
chiped ones, I f everything seems ok its time to get out
you A.C. meter, Disconnect the sensor and probe the wires with your
leads and spin the tire, do this to all the wheels @ almost the same speed
all the sensors should be roughly the same depending on the speed
Im not sure if you can do it with the VAg Com ??
By the way while you having a look make sure the rotor is sitting flush on the Hub
and there is not rust build up around the rotor ...
92audi
Feb 20, 2012 08:03 PM
Bstjohn
Jan 8, 2012 09:23 PM
BaseDrifter
Oct 8, 2011 08:38 AM
sportmpower
Nov 5, 2006 12:48 AM
grrlknyght
Oct 28, 2006 03:04 AM
