Brake warning light when accelerating
Old Sep 28, 2007 | 08:58 PM
onepoint8tee's Avatar
Default RE: Brake warning light when accelerating
Why would you take the time to create this thread without checking your brake fluid level first? Strange....
Old Sep 28, 2007 | 09:09 PM
cincyTT's Avatar
I'm make believe
Old Sep 28, 2007 | 09:17 PM
rofl
Old Sep 28, 2007 | 09:35 PM
B5Bobby's Avatar
my car does the same thing , The brake fluid isnt low at all ....
im thinking its theABS sensor likeAteUrV8said cuz my ABS light flashes too
Old Sep 28, 2007 | 09:48 PM
If it consistantly happens at high rpm's you might have a leak in the brake booster vac line since it works on engine vaccum.
If you had the ABS light tooitd be your ABS module. I dont think it has anything to do with your ABS sensors.
Old Oct 4, 2007 | 07:37 PM
drp1489's Avatar
brake fluid level is fine
Old Oct 4, 2007 | 07:42 PM
cincyTT's Avatar
I'm make believe
That is the only thing that will set it off to my knowledge. Did you atleast top it off when you checked it?
Old Oct 4, 2007 | 07:51 PM
  #18
drp1489's Avatar
didn't have brake fluid but i will. I'll be replacing brake padssoon so i'll replace the fluid and bleed it. we'll see if that does anything
zzr
Nov 9, 2009 05:55 AM
rodick
Sep 8, 2008 05:48 PM
tp
Aug 18, 2004 11:37 PM
