View Poll Results: A poll
GT3076R
27.27%
GT3086R
9.09%
GT2871R
63.64%
Voters: 11. You may not vote on this poll
which BT???
Old May 21, 2007 | 01:51 PM
  #21
cincyTT's Avatar
I'm make believe
Default RE: which BT???
Just replace the rods and at most bore it for some 83mm pistons andyou keep the compression 9.5:1 you will getbetter spool than if you have a 2.0 bottom. Also you will be able to rev the car up to near 8k and have a much longer powerband.
Old May 21, 2007 | 06:36 PM
  #22
scotts custom's Avatar
ORIGINAL: ironman
ORIGINAL: scotts custom
i would get a K04!!!! or even better a K03s, 220 HP is amazing!! lol
f**kin retard, But go Big or Go home is deff the way to go. 450 awhp i cant even believe how crazy that must be.
is there sand in your v****a???
Old May 21, 2007 | 08:25 PM
  #23
theguy1084's Avatar
Yeah I figure with the bottom end that I am getting and a good valvetrain 8k rpms should not be a problem.
Old May 26, 2007 | 11:35 PM
  #24
theguy1084's Avatar
so I am going to stick to stock displacment now. If I stroke it rod angulartity will increase but engine life will go down. If I change the pistons knock voltage will shoot up. So its not worth it
Old May 27, 2007 | 01:25 AM
  #25
Amze's Avatar
ORIGINAL: BaconBait
ORIGINAL: ironman
He was being sarcastic.
How long have you been on the planet Earth Ironman?
Old May 27, 2007 | 12:15 PM
  #26
cincyTT's Avatar
I'm make believe
ORIGINAL: theguy1084
if your worried about knock, water/meth injection will more than tame that, not to mention all the other benifiets. But you can still do wonders with just adding drop in rods (20mm scats or 19mm intergarated engineering)
*up to 00 20mm wrist pins and 01+ are 19mm
