burning oil... somewhat urgent
Old Dec 14, 2007 | 12:30 PM
techbod's Avatar
Default RE: burning oil... somewhat urgent
excessive compression would throw the pistons back causing a timing issue and probably cause a valve strike ( same as the timing belt snapping ) back pressure as its known that for spectrum,
im just giving the basics of the problem as many things can cause this problem but without a personal eyeball Its only a guess
Old Dec 14, 2007 | 03:38 PM
spectrum's Avatar
I think for sure i have a compression issue in a work van I own engine was replaced with used. The problem occurs when engine is turned off after running and warm then minutes later to restart and barley turns once to start.
hainsey
Aug 31, 2012 04:35 PM
rmaugustine
May 2, 2009 04:31 AM
quattro/2.8
May 24, 2008 11:09 AM
muscle750
Oct 18, 2006 04:08 PM
mastermindutz
Oct 18, 2006 01:03 AM
