cam position sensor position?
Old Oct 1, 2007 | 11:50 PM
shelbyturbo's Avatar
Default cam position sensor position?
i've searched til im blue in the face[&:]...im convinced that my question is sooo easy that its common knowledge to everyone else. i've read the post where it is suggested to clean the CPS before replacing and seeing as how it came on once, then disappeard for a couple days and then came back, i would like to try cleaning it...i just dont know where its at.
also can anyone suggest a shop manual for our cars
2002 A4 1.8TQT
Old Oct 2, 2007 | 12:07 AM
onepoint8tee's Avatar
Default RE: cam position sensor position?
Cam shaft pos. sensor is on the right/front/top of the engine right behind the timing belt cover. You can see the wiring harness for it on the side of the engine. There should be 2 metal clips holding the top part of the timing belt cover on. Unclip them and pull back the cover to expose that SOB. A Haynes manual is a good cheap book to start with for most basic stuff. Then there are more complex manuals like the Bentley manual or Elsawin.
Thanks for putting your yr/engine in your signature. Youre a stellar roll model to all noobs [8D]
Peterhopson84
Aug 20, 2013 09:57 PM
MattSCESC
Aug 16, 2011 12:41 AM
RichardAllroad
Jun 12, 2008 01:34 PM
thekyman
Mar 24, 2007 10:13 PM
