Cam tensioner/adjuster?
Old Oct 26, 2007 | 05:40 PM
02A418T's Avatar
Default Cam tensioner/adjuster?
Apparently my cam tensioner/adjuster is bad or something as its leaking a little oil.. I got quoted $450 to replace including labor? Decent price?
Old Oct 26, 2007 | 06:14 PM
02A418T's Avatar
Default RE: Cam tensioner/adjuster?
Also, is it something I shouldnt put off too long? What exactly does a bad cam adjuster effect?
Old Oct 26, 2007 | 06:16 PM
auditech79's Avatar
I think the mechanic means the cam shaft adjuster seals are bad, a bad cam chain tensioner repair would cost you well over $1,000
Old Oct 26, 2007 | 06:21 PM
02A418T's Avatar
My fault, you are correct. Is this a big deal? Is their price reasonable? Will it effect performance, do I have time to replace it, or should it be done ASAP?
Old Oct 26, 2007 | 06:25 PM
auditech79's Avatar
The seal itself only costs $5 on ecs tuning.com, and you need a new valve cover gasket. Its not a bad price but they are really ripping you off because it doesn't take any longer then 1 hour to change the seal.
You need to use a special tool to compress the tensioner, then un-bolt it and you can fish it out with a small pick. If you haven't done it i would just have the shop do it for you. This is the tool you would need.
Old Oct 26, 2007 | 06:26 PM
auditech79's Avatar
P.S its not a big deal un-less its leaking really bad.
Palmer_AUDI
S4
Feb 21, 2014 09:28 PM
jinsojoo
Oct 30, 2012 11:22 PM
Cruz734
Aug 13, 2008 04:02 PM
ayla85
Oct 3, 2007 07:16 PM
ayla85
Oct 3, 2007 11:27 AM
