Camber problems
Old Nov 8, 2005 | 12:28 AM
A4_Spooler's Avatar
Default Camber problems
Since many of you have a different suspension on your a4, I was curious if any of you are having any camber problems. I remember on my Honda I had a hell of a time with camber problems, I assume audi suspensions are built a lot better in the first place but I was still curious if I should expect camber problems when I do change my suspension in the near future, and since we are on the subject, any recommendations as far as suspension is concerned that you would like to pass along? Thanks for any input.
Old Nov 8, 2005 | 12:47 AM
headshok2002's Avatar
Default RE: Camber problems
Well rule #1 is to swap springs AND shocks... I know some crazy people with honda's that cut their springs and throw them back on. Your seatbelt keeps your head from hitting the roof on large bumps.
I lowered a fair bit, and have no camber issues at all. The alignment shop gave me the go ahead to go lower... and I will... once I find a way to stop rubbing.
First step is to figure out if you want a coilover setup, or if you want a spring/shock setup. What's your budget?
Old Nov 8, 2005 | 12:49 AM
Yuikio's Avatar
Sorry. The "sophistication" of the Audi suspension, especially the front, makes it impossible to independently adjust camber. And you can't buy camber plates either, because of the way the upper control arms are mounted. You have to buy CPP adjustable upper control arms,(500$) or adjustable ball joints (200$) or forget it. The same principles apply with the MacPherson strut Honda suspension as the multi-arm setup of the Audi. If you shorten the distance between the strut mounts, or put on springs that have that effect, then the bottom of the wheel kicks out .
Old Nov 8, 2005 | 12:54 AM
A4_Spooler's Avatar
If money really isn't an issue, would you go for the shock/spring setup or the coilover setup? And which one is going to best eliminate future possible problems with camber?
Old Nov 8, 2005 | 01:16 AM
sandman's Avatar
coilovers would be better because if there was a potentiol problem you could just readjust them and go back to stock. but i honestly dont think you will have any problems.
Old Nov 8, 2005 | 02:03 AM
Yuikio's Avatar
My car must have just been fvcked. Coilovers would be the best thing for you.
Old Nov 8, 2005 | 03:20 AM
Slowb5's Avatar
camber...bah, screw it. ill just go thru tires every 5 months.
Old Nov 8, 2005 | 03:23 AM
sandman's Avatar
who else has had problems with this?
Old Nov 8, 2005 | 09:47 PM
A4_Spooler's Avatar
What brand of coilovers would you suggest? H&R?
Old Nov 8, 2005 | 10:19 PM
clconversion's Avatar
bilsten PSS9
sdsteez
Sep 19, 2010 12:33 PM
pyropenguin
May 26, 2010 06:22 PM
supercharged2.8
Aug 12, 2008 11:26 PM
a12gaugehug
Jul 26, 2007 08:57 AM
night rider
Jan 24, 2006 08:19 PM
