Can anyone help me ? Check engine light is on
Old Jul 8, 2007 | 02:00 AM
Mcdonald's Avatar
Default Can anyone help me ? Check engine light is on
Engine:
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 001 - Upper Limit Exceeded
Auto Trans
2 Faults Found:
18171 - Shift Lock Solenoid (N110): Open Circuit
P1763 - 003 - Mechanical Failure
17095 - Shareware Version. To Decode all DTCs
P0711 - 003 - Please Register/Activate - Intermittent
Do you guys know what I should do now?
Thank you !
[/align]
Old Jul 8, 2007 | 02:05 AM
auditech79's Avatar
Default RE: Can anyone help me ? Check engine light is on
You have a vaccum leak, check all your vaccum lines.
As for the tranny fault thats a bad one, get the vaccum leak fixed and erase all the faults and check to see if the tranny fault comes back.
Old Jul 8, 2007 | 11:53 AM
Mcdonald's Avatar
Thank you auditech79
Old Jul 8, 2007 | 12:56 PM
SnowSurfns's Avatar
Member
check the lines under the intake manifold, I had a cracked one under there and just ended up replacing all of them.
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
