Can anyone help me ? Check engine light is on
Engine:
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 001 - Upper Limit Exceeded
Auto Trans
2 Faults Found:
18171 - Shift Lock Solenoid (N110): Open Circuit
P1763 - 003 - Mechanical Failure
17095 - Shareware Version. To Decode all DTCs
P0711 - 003 - Please Register/Activate - Intermittent
Do you guys know what I should do now?
Thank you !
[/align]
Auto Trans
2 Faults Found:
Thank you !
[/align]
You have a vaccum leak, check all your vaccum lines.
As for the tranny fault thats a bad one, get the vaccum leak fixed and erase all the faults and check to see if the tranny fault comes back.
inkhaton
Aug 16, 2012 03:37 PM
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
