Can i replace stock 96 amp w/...
Hey I have the delta 96 audi stereo
Can i replace the stock amp, with my rockford fosgate one and run a sub from it
Is any thing like this possible? This system is decent but i need some bass.
Thanks
Thanks
Well i have a pretty mcuh brand new delta unit from the dealer - 3 months old.
Plus i like the way it looks.
Does that mean it is not possible to do without an aftermarket HU?
Thanks
Thanks
You can deffinitely do this if you wanna (and I would), if you are attached to keeping that deck. It depends how good you are with wiring, but it's very doable. If there's any output run that to the amp, or if not, you can splice in stereo RCA's to the standard speaker outputs and run that to your Fosgate. Good luck,
~Peace
~Peace
Do you have the Bose?
If not then splice of one of the rear speakers to a converter ( takes speaker wire on one side and has a right & left female rca's on the other) from this unit you then go to your amp with the rca's. That will take care of the signal end then you need to run power ground and remote like any amp
Hey thanks for all the help guys
Im gonna try this out today while reading the comments you posted and if I run into problems I will be back (which most likely i will)
but thats just cause ill be baked.
