Can i replace stock 96 amp w/...
Old Jul 1, 2006 | 04:35 AM
mypreludeisred's Avatar
Default Can i replace stock 96 amp w/...
Hey I have the delta 96 audi stereo
Can i replace the stock amp, with my rockford fosgate one and run a sub from it
Is any thing like this possible? This system is decent but i need some bass.
Thanks
Old Jul 1, 2006 | 05:00 AM
Karl's Avatar
Default RE: Can i replace stock 96 amp w/...
well if your going to do that why not replace the Head Unit?
Old Jul 1, 2006 | 08:42 PM
Well i have a pretty mcuh brand new delta unit from the dealer - 3 months old.
Plus i like the way it looks.
Does that mean it is not possible to do without an aftermarket HU?
Thanks
Old Jul 1, 2006 | 08:59 PM
Karl's Avatar
I believe its possible.. not 100% sure though.. some of the other members that have some knowledge about radios will hopefully chime in
Old Jul 1, 2006 | 09:49 PM
silver_bullet's Avatar
You can deffinitely do this if you wanna (and I would), if you are attached to keeping that deck. It depends how good you are with wiring, but it's very doable. If there's any output run that to the amp, or if not, you can splice in stereo RCA's to the standard speaker outputs and run that to your Fosgate. Good luck,
~Peace
Old Jul 1, 2006 | 09:58 PM
Beer Mod's Avatar
Do you have the Bose?
If not then splice of one of the rear speakers to a converter ( takes speaker wire on one side and has a right & left female rca's on the other) from this unit you then go to your amp with the rca's. That will take care of the signal end then you need to run power ground and remote like any amp
Old Jul 1, 2006 | 09:59 PM
Beer Mod's Avatar
BTW I just did this and it sounds great
Old Jul 1, 2006 | 10:22 PM
Beer Mod is saying the same thing I did (maybe a lil' clearer). This is def. the best op. and what I would recommend for sure. Hit this forum back up if you need more advice.
~Peace
Old Jul 2, 2006 | 03:46 PM
Hey thanks for all the help guys
Im gonna try this out today while reading the comments you posted and if I run into problems I will be back (which most likely i will)
but thats just cause ill be baked.
Old Jul 2, 2006 | 03:50 PM
IS there a prefereance on where to run the remote wire?
lifethrasher
Apr 11, 2009 07:25 PM
branden.bounds
B7 Models
Feb 13, 2008 04:56 PM
Blade69
Sep 28, 2007 12:56 PM
Blade69
Sep 28, 2007 11:53 AM
Dave666
Jun 11, 2005 05:26 PM
