Cant communicate with ecu /ecm????
Old Jun 21, 2007 | 10:06 PM
wemmington's Avatar
Default Cant communicate with ecu /ecm????
I had another thread goinghere https://www.audiforums.com/m_564605/tm.htm but alot has happened since so I wanted to start a new one. Quick overview - replaced engine in my 98 1.8t with one from a 99a4 1.8t and it will crank but not start. What i'm tring to figure out now is why I cant scan the ecu. My scan tool says no commincation. I replaced the ecu today and still no luck. I think its a wire we forgot to hook up. If we missed an engine ground would that cause the ecu not to communicate with the scan tool? I checked all the fuses and there good. Im really stumped on this one and need some help.
Old Jun 21, 2007 | 10:41 PM
onepoint8tee's Avatar
Default RE: Cant communicate with ecu /ecm????
I dont have a pic that shows a 2.8 engine, but the grounds might be the same.. Here is one spot to double check:
[IMG]local://upfiles/10408/3F3EFA7BB1B444899A83BFFA686B4332.jpg[/IMG]
Old Jun 21, 2007 | 10:43 PM
wemmington's Avatar
Thank you very very much. I will check that first thing tomorrow.
Anyone else have any ideas on ground locations?
Old Jun 21, 2007 | 10:47 PM
Here is a blurry diagram that says there is a ground in the "battery box."
[IMG]local://upfiles/10408/8EF1F14E0D324E8EA64C720159B13064.jpg[/IMG]
I know it says 98 and you have a 99 engine, but its the same engine code.
Old Jun 27, 2007 | 10:16 PM
wemmington's Avatar
I hate it when people get help on the forum and dont reply back on how they fixed the problem so anyway I got it fixed and details are here https://www.audiforums.com/m_573053/.../tm.htm#573680
fpoljanec
Apr 6, 2014 04:23 PM
fredkhr
Mar 28, 2009 10:12 AM
rohanbambery
Sep 27, 2008 09:02 AM
hbscott35
Aug 27, 2007 07:37 PM
hbscott35
Aug 27, 2007 06:35 PM
