cant find the prob.
Old Mar 12, 2007 | 11:00 PM
2000turbo's Avatar
Member
Default cant find the prob.
I have a 2000 A4, 1.8t,GIAC chip, Baileys DV.
i have been having some problems with my car, when i would boot on it, it would shake and my CEL would come on, so i changed my plugs, and nothing. I had it scanned and swaped my coilpacks, and thought that i had two bad ones, so i bought 2 new ones, it worked fine for like 2 days, but yesterday i booted on it and it shook again and the CEL came back on, i had it read and i had a misfire in cyl.2, wich has a new coilpack, went for a ride and got my CEL to come back on and read it i had misfires in cyl. 2,3. wich both have new coilpacks, but before it was my cyl 1,4. that were missfiring, before i bought new ones. also it reads that my o2 sensonr it out and that i have radom misfires, also that the Internal Resistance is too High, i have no clue what it is,
could it be my ICM, and were is it located on my car.
thatnks a lot for ur help
Old Mar 12, 2007 | 11:04 PM
Lazer Viking's Avatar
Default RE: cant find the prob.
probably your icm
on top of your air box.. the littel plastic thing with wires plugged into it
Old Mar 12, 2007 | 11:15 PM
2000turbo's Avatar
Member
the problem is that it is not there
i changed my stock airbox, and the ICM was missing from it
Old Mar 12, 2007 | 11:22 PM
i cant remember 2000's have icm's or not...
breeze.12's Avatar
your icm was always missing, or you just noticed ther wasnt one? some dont have icms, mine doesnt either. have you unplugged your maf, I was goin crazy untill I changed mine and now everthing beautiful.
Old Mar 12, 2007 | 11:42 PM
2000turbo's Avatar
Member
when i bought the car it was missing
Old Mar 12, 2007 | 11:47 PM
breeze.12's Avatar
they had some changes in the 2000 models, I believe the late model 2000`s didnt have them. yours probably doesnt, If you dont see any wires tucked away , then no worrys.
Old Mar 13, 2007 | 01:42 AM
T28_A4's Avatar
which o2 sensor is it? if its your bank1 sensor1 thats your problem...
Old Mar 13, 2007 | 02:18 AM
onepoint8tee's Avatar
2000+ dont have ICM's. You have a cat fault code because of the misfire. Unburnt fuel/gases going into the cat will cause a cat fault code due to running rich. If youve replaced your plugs and coil packs, I would suspect the MAF. Make sure your coil pack wiring harness/wiring isnt melted too. A bad head gasket can cause misfires too, but thats highly unlikely to be the case.
Old Mar 13, 2007 | 12:37 PM
rbrtech's Avatar
what the code numbers that you are getting?
