Car is broken
Sadly, we didn't use the larger filter until after the Audi memo recommended its use. It's a shame that a car that got fully synthetic oil (except for the oil that came in it from Germany), only went 38,280 miles before it died due to a stubby filter. Oddly, when it was replaced, the Service Advisor said that it really wasn't a sludge problem but more an oil pump "issue" that restricted the lubrication. I never got to see any of the replaced parts, so I can't really comment if it was sludged. It drove great until it locked up. We have an extended warranty and definately use precaution and keep those receipts.
ORIGINAL: cincyTT
the "sludge" is what clogs up the oil pump. You can drop the oil pan and clean everything to prevent/fix this problem.
ORIGINAL: cyberlogicx
Sounds like a worthwile day job! I'm going to do that, but what is this about a bigger filter?
ORIGINAL: cincyTT
The larger filter can be found if you look up a 01+ a4 filter. Its about 1/2" longer and much fatter than the normal filter. It holds about a 1/2quart more oil than the standard filter. If you need bigger, you can get a NAPA filter....aka, THE BIG KAHUNA.
some comparison pics. you can tell which is which.
ORIGINAL: cincyTT
ORIGINAL: cincyTT
