car isn't running after cleaning the TB
Old Dec 22, 2007 | 09:43 PM
moutard12's Avatar
Default car isn't running after cleaning the TB
So I was having an issue with my EPC light and apparently my throttle body, so I took it off and cleaned it was throttle body cleaner. I put it all back together, made sure everything was hooked up, and let it sit at "on" for 3 minutes to reset. I turned it over and it sputtered to a start, then was idling back and forth between 800 and 1200 rpms. There wasn't much of a response when the gas pedal was pressed. I turned it off then on again and now it seems it wont even stay running. It starts for a second, then dies. Any ideas?
Old Dec 22, 2007 | 09:49 PM
Lazer Viking's Avatar
Default RE: car isn't running after cleaning the TB
check your hoses again, it sounds like a leak..
future reference, year, engine, and trans will help us
Old Dec 22, 2007 | 09:52 PM
moutard12's Avatar
ah yea, sorry.
Ill double check the hoses.
2001 a4 1.8t quattro manual
Old Dec 23, 2007 | 12:01 AM
cincyTT's Avatar
I'm make believe
TBA (throttle body alignment). You need one done. Its best to do it with a vag cable, but you should atleast unplug the battery if you dont to reset the ecu and THEN let it sit in the on position.
inflictor
Jan 19, 2017 01:48 PM
Schwalbe181
Jan 29, 2009 05:54 PM
audi_n00b
Jul 28, 2008 11:57 PM
Mya4T
Nov 5, 2007 03:40 PM
j4n3k
Sep 27, 2007 03:53 PM
