car making noises when turning
Old Oct 5, 2006 | 10:48 AM
rnbguy's Avatar
Default car making noises when turning
when im driving and i slightly begin to move wheel to left it makes noises like metal is rubbing together.. this doesnt happen when im turning right, it doesnt happen when im standing still or when im standing still and accelerating at same time... only moving and slightly left?
Old Oct 5, 2006 | 11:02 AM
aRIf's Avatar
Default RE: car making noises when turning
I think axel boot. Boot might be shot and lost all the grease in it. I have the same issue
Old Oct 5, 2006 | 11:14 AM
CRAZYHAWK's Avatar
It could be a right wheel bearing. The sound frequency should change with speed.
Old Oct 5, 2006 | 01:40 PM
joelml's Avatar
sounds like a problem with the cv joint
Old Oct 7, 2006 | 01:12 AM
Johnnyd3689282's Avatar
I had this problem and eventually your it will start doing it on the opposite side. Is it clicking when you turn or does it sound like rubbing??? If its clicking its Your cv joint its cracked. you have to get to an Audi athorized dealership and get it done, because there is a special tool that they have to use, to get it off, if you dont get a audi authorized dealership to use the tool, you abs will get fucked up. So it turns from a 500-700$$$ job to a 2500$$$ job. If its rubbing im not sure what it is.
Old Oct 7, 2006 | 08:45 AM
david9999's Avatar
CV joint usually gives a clicking sound.
Assuming that you don't have super wide tires, or that the interiro wheel well cover isn't rubbing, a grinding or whirring noise that gets worse when you turn away from that side is a wheel bearing.
wolfsangel
May 8, 2010 08:36 PM
liljaiboi05
Mar 22, 2008 04:32 PM
akielb
May 16, 2007 10:14 AM
nazifa4
May 30, 2005 11:15 PM
pauldvern
Dec 7, 2004 09:30 PM
