car shudders and sputters
Old May 22, 2006 | 06:35 PM
badfeet's Avatar
Default car shudders and sputters
so when i start my car up it shudders, and sputters from the tailpipe, it will dip real low rpm's and then jump back up real quickly and the check engine light flashes. It only does this for a minute or so when i start the car up, and then it stops, and the check engine light stops flashing and it drives fine. If i've been driving frequently it doesn't do it at all. But if i go for a few days without driving, it sputters real bad. Any ideas? thnx.
Old May 22, 2006 | 06:47 PM
A4 the Quattro's Avatar
Default RE: car shudders and sputters
get your codes checked..
could be bad gas.. clogged injectors.. bad ground ... fouled plugs... clogged fuel filter.. bad fuel pump.. so many things could be wrong.. get your codes checked at the local parts store if you dont have a vag-com
then we can help you a bit more..
Old May 22, 2006 | 07:43 PM
badfeet's Avatar
will do.
Old May 22, 2006 | 07:45 PM
AteUrV8's Avatar
ya dude it takes like two seconds to get those codes checked, and its totally worth it, lol.
Old May 22, 2006 | 07:58 PM
flyboy's Avatar
ORIGINAL: AteUrV8
I don't know, I've waited as long as 5 sec. for codes. should I get a diff code reader. what do you think.
johncas
Jun 19, 2015 05:32 PM
TT71
Aug 19, 2013 08:24 AM
pa4ul
Feb 25, 2008 01:09 PM
ek4__
Feb 9, 2008 07:20 PM
fumoazul99
Sep 15, 2007 11:30 PM
