Car won't accept gas!!
Old Nov 18, 2007 | 07:18 AM
tml's Avatar
tml
Default Car won't accept gas!!
ok so I just got my b6 3.0 a few weeks ago..filled it up once already no problems..now when I needed to fill it up yesterday as I pressed the nozzle it would flick off as if the car was full with gas....I just barely pumped a few lites into the car...I heard a hissing noise comming from the gas tank....I hope this is no serious problem....anyone can help with info....I tried many things like pumping gas slowly & not jamming it all the way...all I got inreturn was gas overflowwing & me getting pissed off...like ****....how could audi have a problem like this....I can't even put gas in the car......how embarising!!!
Old Nov 18, 2007 | 08:24 AM
techbod's Avatar
Default RE: Car won't accept gas!!
tank vent problem by the sound of it...
Fuel gauge sender[/align]Removing and installing fuel expansion chamber[/align]
Notes:
â—†Observe safety precautions when working on fuel expansion chamber
â—†Remove wheel housing liner in order to remove fuel expansion chamber
Earth connection
â—†Position => Fig. 6[/size]7
â—†Ensure that connector is seated properly on metal ring of filler neck [/ul]
Vent pipe
â—†From fuel tank [/ul][/ul]
Vent pipe
Vent pipe
â—†From fuel tank
â—†White marking [/ul]
Vent pipe
â—†From gravity valve
â—†To activated charcoal filter
Vent pipe [/ul]
â—†From expansion tank to gravity valve [/ul]
Gravity valve
â—†Not available separately as replacement part
â—†To remove valve, unclip upwards out of filler neck
â—†Check valve for through-flow
valve vertical: open,
valve tilted 45 °: closed [/ul][/ul]
O-ring
â—†Not available separately as replacement part [/ul]
Expansion tank
Rubber cup
Filler cap
Seal
â—†Renew if damaged [/ul]
Retaining ring
â—†For rubber cup [/ul]
10 Nm
Overflow hose
Connecting hose
â—†To remove expansion chamber, push connecting hose over fuel filler pipe [/ul]
Fuel filler pipe[/ul]
→ Fig.1Installation position of earth connection
‒Ensure that plug connector -2- for earth connection is properly seated on metal ring -1- on fuel filler neck.
‒After installing the expansion chamber, use an ohmmeter to check the electrical connection between the metal ring on the fuel filler neck and a bare metal part on the body.
‒Specification: approx. 0 ω [/ul][/ul]
If the specification is not attained:
‒Check that the earth connection is properly connected to the earthing point next to the battery. [/ul]
Caution
It is important to ensure that the earth connection is secured at the threaded terminal and the connector is properly seated at the fuel filler neck.[/align]
[IMG]local://upfiles/12092/D90B128C21EB4F38BCCB50F7FA4FAEBD.jpg[/IMG]
[IMG]local://upfiles/12092/E64C3F6C13C34C53A79BEC566A024257.jpg[/IMG]
Old Nov 18, 2007 | 11:35 AM
tml's Avatar
tml
cool thankx...would this th covered under warrenty??
Old Nov 18, 2007 | 01:59 PM
tml's Avatar
tml
I take this is a common problem??
Old Nov 18, 2007 | 09:09 PM
Audipotential's Avatar
Honestly this happens to my car too..its just pressure. Make sure you dont get vapor lock.
angelr15
Mar 20, 2012 02:14 AM
steelcitysfinest69
Mar 26, 2007 11:24 PM
exhonda_nowa4
Aug 29, 2005 12:32 PM
