car wont start and epc light update with codes
Old Dec 1, 2007 | 08:21 PM
khj677turbo's Avatar
Default RE: car wont start and epc light on URGENT
Onepoint8tee, wouldnt that just make sense because the chip doesn't changethe characteristics of theignition, just timing and fuel? or am i wrong?
Old Dec 1, 2007 | 08:24 PM
onepoint8tee's Avatar
ORIGINAL: khj677turbo
Right the coil packs dont recieve more voltage or anything.
Old Dec 1, 2007 | 08:39 PM
A4speed's Avatar
ORIGINAL: onepoint8tee
ORIGINAL: A4speed
chips in general are known to fry coil packs after its been installed, so that is probably it if i were to guess since you just got chipped.
Not sure where you get your info from, but that is 100% incorrect.
EPC light relates to the DBW system and comes on when throtle cut occurs (normally). A throtle body adaptation might be the solution, but if your CEL is flashing, then its probably a coil pack or cracked spark plug insulator.
i read it from one of you top guys a long time ago, so i could easily be wrong.
but yes, that would be a flashing cel light and probably not the epc.
Old Dec 2, 2007 | 02:36 AM
headshok2002's Avatar
I know on the B6 chipping often leads to dead coils... I don't get why, but it's very common.
Old Dec 3, 2007 | 07:25 PM
apr_a4's Avatar
Default RE: car wont start and epc light on updated
ok got some codes
p0300
p0304
p0302
p0351
replaced iginition coils for cylider 2 and 4 still wont start
btw my vag com came in i cant figure it out how to install on vista so i had to use a generic tool
Old Dec 3, 2007 | 07:27 PM
ORIGINAL: headshok2002
B6 coil packs just suck. Thats all there is to it.
Old Dec 3, 2007 | 07:38 PM
hiwords's Avatar
this is for the installation. not much help but it's something. it seems like nothing is firing except
3 lol. culprits: spark plugs, crank sensor, ECT, and ICM.
http://www.ross-tech.com/vag-com/download/current.html
Old Dec 3, 2007 | 08:47 PM
  #18
apr_a4's Avatar
forgot to mention pending codes p0688
Old Dec 3, 2007 | 09:13 PM
  #19
Bogie's Avatar
OH BOY. I just put in my speedtuning chippedecu tonight. The car runs fine and never had coil pack problems so I have never replaced them.But mine is a 2000 B5, so are mycoil packs any better? I just don't want to havethis problem happening to me when I'm driving to or from work this week. Idid a quick testdrive,but didn't really push the car because it was snowingout and I didn't get out to the highway.The chip does definitely give more power...but I'mgoing to keep the 8mmwrench and stock ecu in my car just in case...althoughthat won't fix a bad coilpack, icmor crank sensor... good luck apr_a4 and let me know what happens.
Old Dec 3, 2007 | 10:13 PM
  #20
ORIGINAL: Bogie
ATW enginecoil packs never go bad. We are just lucky like that [8D] 2000+ dont have ICM's either, so we are sitting pretty as far as ignition components go.
