car wont start and epc light update with codes
Old Dec 3, 2007 | 10:22 PM
  #21
99A6Q's Avatar
Default RE: car wont start and epc light on URGENT
sounds like your crank sensor is toast apr_a4
Old Dec 3, 2007 | 10:48 PM
  #22
Bogie's Avatar
ORIGINAL: onepoint8tee
ORIGINAL: Bogie
OH BOY. I just put in my speedtuning chippedecu tonight. The car runs fine and never had coil pack problems so I have never replaced them.But mine is a 2000 B5, so are mycoil packs any better? I just don't want to havethis problem happening to me when I'm driving to or from work this week. Idid a quick testdrive,but didn't really push the car because it was snowingout and I didn't get out to the highway.The chip does definitely give more power...but I'mgoing to keep the 8mmwrench and stock ecu in my car just in case...althoughthat won't fix a bad coilpack, icmor crank sensor... good luck apr_a4 and let me know what happens.
ATW enginecoil packs never go bad. We are just lucky like that [8D] 2000+ dont have ICM's either, so we are sitting pretty as far as ignition components go.
Thanks onepoint8tee, that's one less thing that can possibly go wrong tomorrow... hope nothing does. I'm really not a pessimist, but it seems like a lot of guys having problems with one thing or another soon after chipping.
Old Dec 4, 2007 | 12:04 AM
  #23
apr_a4's Avatar
ORIGINAL: 99A6Q
i sure hope not im going to have a local tech look at it this weekend
Old Dec 4, 2007 | 12:07 AM
  #24
onepoint8tee's Avatar
ORIGINAL: apr_a4
ORIGINAL: 99A6Q
Sounds scary.... Is he vw/audi certified? Most non Audi certified mechanics pee their pants a little when they seean Audi roll up that doesnt need a tire plugged.
Old Dec 4, 2007 | 12:16 AM
  #25
apr_a4's Avatar
ORIGINAL: apr_a4
ORIGINAL: 99A6Q
he is tight on cash he is litterly counting pennies, he will come for sure since he is trying to leave the stealership because he just opened up his own germanrepair shop and has most of his tooks with him all the time
Old Dec 8, 2007 | 10:02 AM
  #26
rideserotta's Avatar
I have an 06 A4 Avant 3.2Q 6M. Every once in a while when I crank the car the EPC light and traction control light light comes on and there is no power. I took it to the dealer and he said no codes, and since it only happens every once in a while it'll be hard to track down. He said he "reset" everything and maybe that'll take care of it. Well, 2 days later the same thing happened... started the car at lunch, EPC light, no power. I just turn it off and then restart and everything is fine.
Any ideas?
Old Dec 8, 2007 | 10:53 AM
  #27
mojo5436's Avatar
I had the same exact thing happen to me a couple days ago. It was frigid out (about zero degrees) when I came out to my car in the morning. Started it up, EPC and CEL came on and then it goes into limp mode. After I let it idle for quite awhile and warm up, turn it off, restart, all is good. Drove about 15 minutes to work without anymore problems (CEL did stay on steady). Cruised over to autozone at lunch (started fine this time, no limp mode, no EPC, CEL stayed on steady) and had them pull the codes: P2101, Throttle Actuator Control Motor Circuit, Range/Performance. I also performed a Throttle Body Adjustment (TBA) (turn the car on, but don't start it, hold the gas pedal to the floor for 5 seconds, turn the car off, take your foot off the gas, leave the key in the ignition the whole time, wait about 2-3 minutes for a full adjustment) at lunch, not sure if that helped or not. There isn't much history on this on this code in the forums (searched audiforums, audiworld, audizine..) but I did find this on AudiWorld.
Basically, after work that same day, the CEL went out (didn't clear the codes or anything) and it hasn't come back on. I think my issue was directly related to the cold weather I was experiencing. You could try a TBA, or else you might be looking at a new throttle body if you continue to get the errors, not sure though.
Old Dec 8, 2007 | 11:03 AM
  #28
ORIGINAL: rideserotta
Any ideas?
Keep reporting it to the dealer and make sure a record is made of it. In other words, and unfortunately, take it in every time it happens until its resolved.
Also, read this
Old Sep 1, 2011 | 09:00 PM
  #29
AUDILVE's Avatar
check 1) engine speed sensor 2) throttle position sensor - turn key to 2nd ( dash lights) press accelerator 10 times and take key out and start car, if it fixes problem then its that if it doesnt 3) if it was raining during this trip you wiring harness could have an exposed wire and it short circuited and freaked your ecu, as much as i've read up on it its usually 1 or 2 and rarely 3
boostedc5
Apr 11, 2011 08:29 AM
LRpgulf77
Feb 6, 2010 08:45 PM
thepirate
Dec 18, 2007 09:19 PM
ezlnh8u
Sep 25, 2007 05:25 PM
ezlnh8u
Sep 24, 2007 06:41 PM
