CAR WONT Start HELP!
Old May 29, 2007 | 11:58 PM
akielb's Avatar
Default RE: CAR WONT Start HELP!
Sorry to hear about that - hope you have an extra $3-4k in your pocket
new valves - machine the head - new TB........and the list goes on
Old May 30, 2007 | 12:12 AM
headshok2002's Avatar
I wouldn't even waste your time putting on the new belt... you heard a "scratching" sound... me thinks that was the pinging of your valves getting acquainted with your pistons.
I'd take the head off, if you can confirm that the belt did indeed break.
Old May 30, 2007 | 01:28 PM
jduplooy's Avatar
So What should I look out for, regarding damage to the engine?? I realize the the exhaust valves could be bent, but is my Cylinder head in danger too?? What all do I need to look out for??
Old May 30, 2007 | 01:30 PM
jduplooy's Avatar
And just to add.. It looks like the belt didn't exactly snap, but the teeth wore on alot of the belt. The belt is still intact, but it will not exactly work if that makes sense. I figured that this could possibly be better news than a complete snap or break in the belt.
Old May 30, 2007 | 01:33 PM
techbod's Avatar
you should always fit a new belt to see if it had valve impact also you can do a compression test, chances are you stuffed 6 valves though and good luck
Old May 30, 2007 | 01:39 PM
akielb's Avatar
Sounds like your TB tensioner broke(more common than the belt snaping). The tesioner is the reason people say to do the TB job every 70k. when the belt skipped it might have sheered off a few teeth.
Valve damage is caused by the piston hitting them - which in turn scar's up the piston - the valves then hit the cyclinder head.
Right after I did my TB I went to my local shop and they guy says "hey wanna see what could have happened if you didn't do this" well he had a volvo in there, bent 18 of 24 valves scared a couple pistons and the head needed to be redone. total cost $4k
Old May 30, 2007 | 01:52 PM
jduplooy's Avatar
I guess the only real way to find out is to do it. Thanks guys. Will post back when I find out more!
Old May 30, 2007 | 01:59 PM
  #18
techbod's Avatar
good luck
Dylan Cure
Sep 4, 2012 04:21 AM
zslatcher
Oct 24, 2011 06:15 AM
Billydakid
Oct 29, 2010 02:40 AM
