Car Won't Start need some help
Old Jun 24, 2007 | 08:10 PM
OrangeA4's Avatar
Default Car Won't Start need some help
So my car won't start after I did some maintenance work on it to fix/swap out old things for new pieces. When pressing on the clutch petal then turning the key in the ignition the dash monitor thing still says press clutch pedal to start car, which what I was already doing. Also my EPC light stays on with the key turned. When the key is turned there's a weird noise that emanates from around the brake area/car computer. If no one has any advice I think I'll have it towed to the dealership to have them check it out since I don't have access to a Vag-com.
Old Jun 24, 2007 | 10:23 PM
OrangeA4's Avatar
Default RE: Car Won't Start need some help
anyone?
Old Jun 25, 2007 | 12:37 AM
acetrebo's Avatar
What exactly did you swap out, and do to the car?
What year/engine is the car?
Old Jun 25, 2007 | 02:10 AM
OrangeA4's Avatar
it is a 2000, and we swapped out the clutch, pipes, tubes, and got the flywheel resurfaced. But doesn't matter no more. We figured it out, it was the power for the starter motor that had come unplugged during reassembly of the car, took us a lil bit to fix and now it runs fine
Old Jun 25, 2007 | 06:47 AM
theguy1084's Avatar
Chito
Jun 28, 2010 08:48 PM
mark944turbo
Oct 10, 2005 05:51 PM
