CEL came on and have 10 different codes
Old Sep 5, 2006 | 06:42 AM
tonelee1316's Avatar
Default CEL came on and have 10 different codes
Can any one please help????
Went to autozone to diagnose my car and came up that i have 10 fault codes, so here they are them:
P0444- Evap emission control system purge valve c open
P0037- Ho2s bank 1 sensor 2 heater circuit low
P0418- Secondary air injection system relay a malfunction
P0412- Secondary air injection system valve a malfunction
P1289- Manufacture control feul air metering
P1472- Manufacture control auxilary emission controls
P0136- o2 sensor circuit malfunction (bank 1 Sensor 2)
P0031- Ho2s bank 1 sensor 1 heater circuit low
P0102- MAf or CAf circuit low input
P0135- o2 sensor heater circuit malfunction (bank 1 Sensor 1)
This car by the way is a 01 a4 1.8t quattro manual
I also have a blown fuse in spot #34(control engine unit) and i change it twice but it keeps blowing on me. i am pretty sure that it is the reason but dont know how to fix it so am asking if anyone knows on how to fix it. this all started happening after i had a shop replace my clucth. Your help will be greatly apprecaited. Thanx in Advance!!!
Old Sep 5, 2006 | 07:32 AM
techbod's Avatar
Default RE: CEL came on and have 10 different codes
P1289 is a shorted wire to negative on the turbo bypass valve ( probably the cause for some of the other codes ) the rest all indicate shorted or bad grounds, check the wiring for damage
Old Aug 30, 2011 | 12:17 AM
Serjay's Avatar
Have you fixed all the codes you had, the check engine light issue? I have the same problem any advise?
Thanks
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
Ruggedboy
Jul 20, 2007 11:30 PM
supercoupe91
Jul 13, 2007 06:20 PM
rafa_207
Jun 27, 2007 01:31 PM
