CEL question(yes i searched)!UPDATE!
Old Nov 10, 2006 | 11:55 AM
a4sport's Avatar
Default RE: CEL question(yes i searched)!UPDATE!
That's why they made CEL's, to tell you when something is wrong. Find your nearest Autozone, have the code scanned, and then post it up. Simple as that. Then we can help.
Otherwise, just drive it with the CEL on til' the car dies.
Old Nov 10, 2006 | 12:50 PM
wood_e's Avatar
obviously you didn't do any searching. This is discussed nearly daily here. Get it scanned and figure out why its on. Prolonged CE lights can cause bad things. The 87 gas probably didn't do any damage.
Old Nov 10, 2006 | 02:55 PM
david9999's Avatar
I'm guessing a bad oxygen sensor.
Old Nov 10, 2006 | 06:38 PM
PandaXpress's Avatar
he could be low on fluids cause low coolant gave me a CEL
Old Nov 10, 2006 | 06:55 PM
onepoint8tee's Avatar
ORIGINAL: PandaXpress
wwwwwwwwhat? You had a CEL w/fault code that said "low coolant"?? Never heard of that one...
Old Nov 10, 2006 | 07:00 PM
techbod's Avatar
im not guessing, get it checked, low coolant will set the CEL because the oil takes over cooling the engine so its a warning the cylinder head is about to blow
Old Nov 10, 2006 | 11:38 PM
01A4T's Avatar
you guys are right, i will scan it at autozone. i will let you know the codes.
thanks for the input
Old Nov 11, 2006 | 02:25 AM
  #18
turbo kraut's Avatar
Tech Guru
just fyi i went to autozone and they told me they might not be able to read an audi so you might have to take it to the dealership or find someone near you with vag-com
Old Nov 11, 2006 | 05:17 AM
  #19
01A4T's Avatar
anyone in chicago have a Vag-com? im located in Licoln Park. i am also in the Naperville area too. if Autozone cant scan my car then im not sure what to do.
Old Nov 11, 2006 | 01:25 PM
  #20
CRAZYHAWK's Avatar
http://www.steve-hall.com/cgi-bin/VAG-Locator.pl
markymarc
Apr 20, 2009 01:36 AM
01afour
Feb 12, 2008 10:12 PM
Hey_You
Jul 6, 2007 10:12 AM
edkwok
Jan 19, 2007 04:39 PM
Mott Power
Apr 16, 2006 04:06 AM
