cells
Old Feb 28, 2005 | 08:00 PM
2.8AudiA4's Avatar
Default cells
is there any way to reset the ECU i got a check enigne light one night when i messed up down shifting into 2nd ther was noise such as grinding cause i did not push in the clutch all the way werid thing is the next night the cell/ check engine light went away. i was cool but then a week later it came back. thing is the car runs perfectly fine there is nothing wrong with it and all gauges are correct jw wondering if someone knew something ty
Old Feb 28, 2005 | 08:30 PM
Jestnomen's Avatar
6th Gear
Default RE: cells
you need to get the car scanned for the code. Your downshifting is a highly unlikely reason, as CEL usually are triggered by emmissions related things. Go to autozone and get it scanned for free, and bring the code back. And yes you can reset your ECU by disconnecting the battery for a half hour or so. Make sure you have your radio code handy.
Old Mar 1, 2005 | 12:27 AM
2.8AudiA4's Avatar
Default RE: cells
i have an after market system i dont think i need it then right?
Old Mar 1, 2005 | 12:33 AM
Doose's Avatar
Default RE: cells
If you are referring to your ECU being chipped, yes, you still need a scan to get the CEL codes.
Old Mar 1, 2005 | 12:35 AM
Jestnomen's Avatar
6th Gear
Default RE: cells
ORIGINAL: 2.8AudiA4
if you have an aftermarket, the disregard my radio code comment.
jxpar24
Aug 15, 2006 12:21 PM
