Center Console Removal?
Old Jul 21, 2005 | 02:18 AM
apg96's Avatar
Default Center Console Removal?
How do i remove the center console. I am installing my shifter an dit says taht if i dont have a shifter plate cover that i may need to remove it and sinc ethe next piece cant come out w/o this i need to remove it. I dont have a little piece that soem cars have that just pops out.
Old Jul 21, 2005 | 02:57 AM
trailboss's Avatar
Default RE: Center Console Removal?
you shouldn't have to remove the center console. Is it the 4 nuts that are 10mm i believe that holds the shifter assembly up. If its those 4 then get a flat wrench and use that for the hard to reach one's. Removing the center console is a pain in the ****, also if you have a telescoping magnet on hand that will save you from having to remove the center console cause you may drop a few bolts and nuts. On the newer a4's i think either 99.5 or 2000 the opening for the shifter is alot bigger at least 1" every which way, the older ones with push-down suck, not alot of room to work with.
Old Jul 21, 2005 | 03:02 AM
apg96's Avatar
yea thats what i have. I will try the flat wrench,
Old Jul 21, 2005 | 03:08 AM
apg96's Avatar
it doesnt work it wont reach. HOw do i get that fuking center console out of my way. I dont want to have to deal with it!.
Old Jul 21, 2005 | 04:06 PM
brrman's Avatar
see my reply in your other post
Old Jul 21, 2005 | 04:21 PM
Yuikio's Avatar
http://www.audiworld.com/tech/int.html
Just know that the actual steel, painted frame of the car extends over the nuts you're trying to get off as well. You still won't be able to put a ratchet over them. I think.
Old Jul 21, 2005 | 08:53 PM
apg96's Avatar
the tech write ups to insatll the shifter isnt what i need. I have that from b&m. http://www.bmracing.com/media/products/pdf/25.pdf look at step 4. That wood piece doesnt exist on my car.
imaudi5000
B7 Models
Jan 25, 2012 03:10 PM
Nevalite
Mar 25, 2011 06:34 PM
bronxblaza117
Jan 9, 2008 11:15 PM
csuflyboy
Sep 6, 2006 07:41 PM
Dunzie182
Apr 27, 2006 12:33 AM
