change tray stuck
Old Apr 10, 2006 | 09:28 PM
04a4's Avatar
Default change tray stuck
Ok i know this has been posted before, but i can't find it and am hoping that someone can help me out...
My roommate the other day jammed a few hundred bux in my change tray and now it is jammed shut. does anyone know how to un jamm the tray or how to take it apart????
I have uploaded a photo of the tray i am talking about...it is right of the ESP button and Right of the Drink tray....
[IMG]local://upfiles/2145/A148ADF0DF2B480889C7A8C7A81BAD23.jpg[/IMG]
Old Apr 10, 2006 | 09:39 PM
forcefedaudi's Avatar
Default RE: change tray stuck
mine gets stuck all the time, get a flat head scredriwer or a small knife and carefullf pry foward.If it dosent want to open push it slosed all the way and try again, eventually itll pop.
Old Apr 10, 2006 | 09:46 PM
04a4's Avatar
tryed that, but it started to f' up the dash... i would rather know how to take it apart and then put it back together rather than just jamming things into it trying to pry it open...i've had things break that way and i know i won't be able to open it up that way
Old Apr 10, 2006 | 11:08 PM
it should just pop out but if you want to take the console aprt there should be tabs under the dash and bye the seets that have hex head screws under them.My console is set up different though i have an 01
Old Apr 11, 2006 | 12:08 AM
04a4's Avatar
sweet just figured it out...had to pry off the top trim piece and then there were two clips that need to get pryed off and the try just slid out...
Old Apr 11, 2006 | 02:00 PM
brrman's Avatar
unfortunately you will have to remove the interior trim to get at it completely. that means removing the radio. We all know what a PITA that is.
Trigger200
B7 Models
Apr 27, 2015 11:58 PM
Phil123
B7 Models
Aug 15, 2010 11:17 AM
Optical Serenity
Nov 26, 2006 09:23 AM
betz470
May 10, 2005 08:35 PM
