Changing the oil... we have a problem.
Old Nov 22, 2006 | 08:21 PM
pyropenguin's Avatar
Default Changing the oil... we have a problem.
My oil drain plug wont come out! Last oil change, I had a local performance shop change it for me, and I think they torqued it down WAY too much, and it doesn't look like they even put a washer on it... stupid guys.
So, I've cranked on it as hard as I could, pushing, pulling, and it wont come loose. I sprayed some wd40 on it about 5 minutes ago and we'll see how that works to loosen it up.
Any tips on getting it out? haha.
Old Nov 22, 2006 | 08:30 PM
acetrebo's Avatar
Default RE: Changing the oil... we have a problem.
Yes.
Another one for the list of must have tools for any DIYer.
Get a breaker bar and try that. Its just a longer socket bar to give you more leverage.
Or, if you have a piece of heavy pipe around, slide a piece of pipe over the wrench handle to make it longer giving you more leverage.
OK, dumb question, are you sure your turning it the right direction?
If you are looking straight at the bolt =>> righty-tighty (clockwise) and leftly-loosey (counter-cw).
Old Nov 22, 2006 | 08:33 PM
I'll have to look into a breaker bar before I attempt the shocks/springs myself. yeah, I tripple checked myself to make sure I was doing it the right way, it happens though.
Alright, heading out to see if the wd40 helped. If not, I'm searching for some pipe.
Thanks,
Kyle
Old Nov 22, 2006 | 08:56 PM
ProOnThaSnow's Avatar
if worse comes to worse, use the close end of another wrench, and put it on the open end of the wrench you are breaking the plug lose with.... when I was working at a shop, you'd be amazed how many times I've actually been able to pull myself off the ground (6'4" 225lbs) trying to break loose an overtightened drain plug. Usually a breaker bar does the trick, or if you feel ballsy the wrench trick, just make sure you don't slip and smash your fingers/hand into something. The E-R isn't very fun.
Old Nov 22, 2006 | 08:58 PM
Well, it's pouring rain now, so much for changing the oil today.
I guess it will be waiting for me on Friday when I get back in town. Thanks guys.
Old Nov 23, 2006 | 03:31 AM
Amze's Avatar
haha good luck
Old Nov 23, 2006 | 03:39 AM
18T's Avatar
18T
yeh shops tend to do that.
Old Nov 23, 2006 | 03:47 AM
Lazer Viking's Avatar
... almost as bad as breaking a stud off a lug nut on the side of the road with only a 4way lug wrench to do it... needless to say that was a slowwww drive home with 4 lugs holding the tire on an old *** ford
Old Nov 24, 2006 | 05:26 AM
wood_e's Avatar
This is why everyone should have a nice air compressor on hand and an impact wrench. That combo has loosened many drain plugs of my friends, put on by shops.
ex56TT
Mar 14, 2014 08:47 AM
indriti632
Feb 7, 2011 04:58 AM
Ace607520
Oct 4, 2010 06:13 PM
punkrocker5817
Aug 14, 2009 11:49 AM
playboy00786
Jul 3, 2009 11:34 PM
