check engine light
Old Oct 19, 2005 | 02:35 PM
dubiousmusic's Avatar
Default check engine light
bahh my check engine light came on this morning.
Old Oct 19, 2005 | 02:37 PM
cary12's Avatar
Default RE: check engine light
LOL. Mine comes on once a week. Just like when I had my VW VR6.
dankhound's Avatar
Whats the code?
Old Oct 19, 2005 | 02:42 PM
the engine code?
Old Oct 19, 2005 | 02:58 PM
audiboy6789's Avatar
no dubiousmusic the engine code is somthing different.
but i was wondering how do you find the code my engine light is on too and i couldnt figure it out?
Old Oct 19, 2005 | 03:22 PM
BFlan2001's Avatar
you have to scan it with either a vag-com or a generic obd2 scanner. loaner tools are usually available at autozone for free, although they will usually make you leave a deposit for the cost of the scanner. the port to plug into is either under your dash on the driver side, or next to the rear ashtray on the center console. i believe they moved it under the dash in 99-00
Old Oct 19, 2005 | 07:00 PM
John_E's Avatar
Buy a bottom-of-the-line generic OBD II "pocket scanner" when they go on sale at $60 at your local Pep Boys, AZO, or Kragen/Schuck/Checkers. Even if you later spring for the full RossTech VAG-COM, you will find the pocket scanner very convenient for initial assessment of MILs. You may even want to carry it in your glovebox to assess the urgency of any MIL you get whilst out on the road.
Old Oct 19, 2005 | 07:11 PM
sammodon's Avatar
to simply turn off the light, you will have to reset it, but then again, u will need a VAG-COM for that...
Old Oct 20, 2005 | 01:32 AM
BFlan2001's Avatar
ORIGINAL: sammodon
that's not true. almost every obd2 scanner, even the least functional ones, will still clear codes.
Old Oct 20, 2005 | 04:19 AM
sandman's Avatar
go to your local auto parts store, most likley they can scan it for you and give you a code. then post this code and maybe we can help.
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
